Looking for intructions to DIY front bumper removal. I removed the 4 - 8mm bolts on the bottom of the bumper 2 per side in front of the wheels. I also removed the plastic pins holding the bumper to to the front eng skirt.
I'm looking for the two 8mm bolts, one in each wheel well.
I can see four 8mm bolts, two in each wheel well and 2 plastic pins, one in each wheel well. Do I need to remove all of these? Is this the difference from the DIY Coupe instructions online and my 4 dr sedan?
I also loosened the two torx bolts from under the front bumper lip, through the slots.
I think I need to slide the wheel well lining outside the bumper edges seperating the lining from the bumper at both wheel wells.
Now if I can just figure out either which two 8mm wheel well bolts to remove or do I also pull the plastic pin clips. Guess I can remove all the bolts and pins I can find for now, remove the bumber and see which ones actually didn't need to be removed but if you can help me out I would appreciate it.
Do I need help removing the bumper myself because of the fog lights?
Your responses are appreciated. Thank you!![Pray [pray] [pray]](/images/smilies/icon_smile_pray.gif)
