1988 325is speedometer
bpeesy
arizona
My 88 325is speedometer/odometer is no longer working. I'm assuming it has to do with the speed sensor. Can anyone out there advise me where I can find the speed sensor on this car
174
Oregon
Yep the speedo sensor is on the back of the rear differential. Not hard to find, the only wires running into it I think.
It might not be that though. The speedos in our cars have a plastic gear inside the mechanism somewhere. Over time they break. You can get a replacement gear for it.
Do a search on this website and you should find some info about the speedos going bad. When one went out on me, I could get it to work sometimes by slapping the dash near the speedo. But after a while that stopped working also.
Aaron
22
Connecticut
I say remove your dash take out the speedo replace it the wiring and the sensor, and you'll be good to go...if you don't want to spend all that money/time, just start with the sensor and work your way back, kind of a guess and check procedure, the only problem with this is if its not the sensors or the wires and actually is the speedo, then...you'll have a lot of time money and aggravation, when you could have saved yourself by just doing it all the first time... oh well do what you thinks best.
