Hey guys I was hoping someone had a idea about my clutch problem. I have an 1983 stock 320i. I have a hydraulic clutch with a, I suspect, an easily identifiable problem. The brakes are fine and the system is not losing fluid. It started out that it would only loose pressure slowly when the clutch pedal was in the middle, NOT at the top or all the way depressed. Now it loses pressure very fast anywhere. I rebuilt the slave cylinder a couple years ago and it has been working great for that couple years.
The thing that makes it interesting is that if the pedal is not pushed, it will build back pressure on its own after a 30 seconds or a minute or so. I suspected a vacuum leak, but can't hear any air noises. I am really low on cash these days and can't really afford to have it fixed by someone else and I can't afford to fix things that don't need fixing right now. I am guessing that someone will know right off the bat what the problem is. I hope!
Thanks in advance for any help,
Keeper
Keeper
