BMW Punk said:
			Ok so I may be dense but.... How do I know if the A/C system is on in my 1986 325e? Is it on when the push button switch is in or out. when it is ouy the switch lights up blue. Also when I turn on the fan switch the blue light goes out? so how do I know?[???1] [???1]
 Sounds like you might have some sort of electrical problem here.  Here's how it should work:
With the snowflake button out, it should not be lit up blue.  When you push the snowflake button in, it should turn blue, the compressor will engage, and the fan should turn on the lowest setting even if the fan selector is set to 0.  If you turn the fan switch to a higher setting (1-4), then the blue snowflake should stay on and the fan should simply run faster.  If you push the snowflake button to pop it back out, the blue light will turn off and the compressor will disengage.  The fan will stay running at whatever speed you have it selected at until you switch it back to 0 to turn it off.
Basically, the A/C is on whenever the snowflake button is pushed in and lit up blue.  Selecting any fan speed should not turn off the blue light, because the fan will always run at at least the slowest speed whenever the snowflake button is pressed in and the compressor is on.  Turning the headlights on doesn't light up the snowflake button when the A/C isn't on, at least not in my car.
