What I mean is the following:
I have two belts up front; the Serpentine Which is connected to damn near everything (alternator, crankshaft, power steering, etc). Then in front of that belt is the A/C compressor belt. Two pulley and an "adjuster" touch this belt. The (I believe) crank pulley works fine. The other pulley is the one that I am referring to and the following description is how it works.
(1) When the A/c is off:
The out side of the pulley (the grooved circle that is actually touching the belt spins. It spins whenever the engine is on. The inside of this pulley (there are some screws etc, that hold it in) does NOT spine when the A/C is off.
I know that this is normal
(2) When the A/C is ON & the compressor is off:
The conditions are the same as described in subsection (1).
(3) When the A/C is ON & THE COMPRESSOR IS ON:
The inside of this pulley spins in tandem with the outside of the pulley (outside of pulley being described as the grooved bit that actually touches the belt).
When I revved the engine (presummably to 1100 rpms), it made that awful sound and the INSIDE of that pulley stopped or hestitated or paused or was interrupted in some way and stoped moving for the briefest of moments. Then within a second, the sound goes away and the inside of the pulley spins in tandem with the outside of the pulley until the compressor switches it self off.
Is this clearer, Dan?
