It will not plug-and-play. It doesn't matter if you have nav or not as to which adapter to use, but you will need an adapter. Check my signature. I got all my stuff from logjam. The install is straightforward. The adapter connects to the 6-pin and 3-pin (meant for a factory/OEM changer) and your changer connects to the adapter with another adapter cable.
