Tie rod ends, control arms (includes the front ball joints), CA bushings (recommend M3 1s if you have wider wheels), subframe bushings (incl diff bushing), trailing arm bushings, front strut mounts (bearing set and mount in one), rear shock mounts (use E46 cabrio mounts).
Most of those are not that bad, the trailing arm bushings are a bitch. Once you do the back it should last a while. They recommend watching the front like a hawk when you race, to the extent of replacing the control arms every few years just to be safe.
If you are planning on putting springs/shocks in the go ahead and do the shock mounts both front and rear. The mounts are not that much money and the work involved in removing them is prohibitive, so do them in conjunction.
