Appearance Question
David2005
8
Virginia
The black strips that run top to bottom at the rear of the driver and passenger windows are starting to discolor a little. I assume this is caused by grabbing that strip to close the door when exiting the car. It doesn't look terrible but I assume it will get worse if I don't do something.
Any ideas about what to use to fix the problem? Wax, rubbing compound?
Thanks, David
Thanks, David
Are you talking about the plastic? No to wax or rubbing compound. I'd put a plastic/rubber trim cleaner on there. Meguires makes a spray. BMW use to make a gummifledge.
Or are you talking about a painted piece of painted plastic, like the bumpers? Then yeah, i'd treat it the same as the body of the car.
