I have a 2002 330i and noticed a faint noise coming from my fan belt or pully set. It is a chirping/ squeel that only is noticed when the car is in gear at idle. It is only noticed if you are outside the car (can't hear it inside the car unless the window is down and there is no other noise present). In park, it does not make any noise and when it is in gear, the noise goes away after 800 rpm's. The situation does not change when switching the a/c off or on (a/c compresser) and it doesn't change when turning the steering wheel (power steering). I assume it might be a bearing, but I dread the thoughts of replacing something expensive over a very slight squeak that occurs only at idle in gear. Any ideas what to expect or has anyone experienced this?
Thanks.
Thanks.
