ok so the problem is that everytime I start the car when the engine heats up the antifreeze starts leaking out the bottom(i don't know if its leaking out the radiator or if its just a hose)of the car. First thing I thought was blown head gasket but theres no steam coming from the tail pipe, and I took the cap of the radiator and let it run and once again as soon as the car heated up I saw bubbles which means air. SO i need to no what I should do from here.
