i was once told that the bmw keys work from farther if its closer to your head--that your head acts like an antenna. i tried it out and if you hold your keys in your hand at a distance away from your head in front of you (with your arm extending forward), and you're far away for the car not to unlock, and then u put the key close to your head in that same spot, it unlocks. it seems to work. this must mean that your head acts like an antenna. i've done this several times, and it seems to be true, that your head is the antenna. so i'm wondering whats in the key, or for that matter whats in your head that makes it work that way. its very strange.
