Brake light indicator 328ci-2000
mcbeamer
11
san diego
Hi,my name is ken,i just hooked up with a 2000-328ci and i love it.Im sure glad this forum is here i have learned alot.Question-my brake pad indicator went off [scratch] so i changed my back indicator and pads for my front were ok and my light on dash will not go out.does anyone know how to get that darn light off.I take my car into dealer next week for first inspection and i dont want them to give me a bill for screwing with my brakes because my light is on
I would just ask them to turn it off, they should do that without charge. I stopped replacing those redundant sensors a long time ago...I haven't used them since about 2001.
54
N.C.
There is a way to bypass the sensor like stated above but there is no reason to do it. For one the sensors are not that expensive. for two i find them very helpful becasue they let the pads get down to minimum spec before they come on. To turn the light off just leave the key on for about 30 to 60 seconds and that should take care of it as long as the sensor is new and plugged in.
mcbeamer
11
san diego
Thanks Nathan56989 ,
your tip worked. I also find the sensor very helpful. I change front and back sensors just could not get the light out on dashboard. Again thanks
usedweb
6
Massachusetts
Hi,
I just installed new rear brake pads on my 2000 328i, but the indicator on the dash is still on.. I have been driving with the indicator on for a few days now... Any thoughts? Thanks in advance!
-- Ed
405
Los Angeles, CA
there is a brake sensor cable that you have to replace as well, i believe. when the brake pads get worn down, the cable is designed to break, thereby triggering the warning light on the dash. so, u have to replace both the brake pad and the sensor cable, which i believe is a bmw-only part- ie no aftermarkets equivalents available. make sure u check all the connections are firmly in place, then drive around a bit, and the brake warning light will go out by itself, cuz sometimes it doesn't turn off right away...
usedweb
6
Massachusetts
Thanks guys! It worked... I had to leave the key on for about 30-60 seconds on the third position.... without turning on the engine. The break pad indicator went away. SWEET!
polygaryd
9
massachusetts
how much are those brake pad indicator sensor cables and also does anyone have a link to how to bypass them?? most after market pads have squeal pins on them so i usual replace them when it squeals i would rather not have to keep buying sensor cables and turning off light in this damn car..
polygaryd
9
massachusetts
ok found the sets at autozone for about 50 bucks front and back aftermarket price i dont know what the dealer charges but that is a bit much for me anyway.. please get back to me on how to bypass them
