brake pads
59
Loma Linda
Well i was going to change my rotors and brake pads but after the rotors have been changed i cant get the new pads on. I have decompressed the hell out of that piston but both the pads just wont fit. What do i need to do. 1989 325i
axle
Have you opened the bleeder valve and used a pair of channel locks to compress the piston back? Sometimes it is a very close fit, however they should go. Remember if you get air into the system your going to have to bleed the brakes.
junglestylz
1,024
Las Vegas, NV
If you do as big daddy said but take a crescent wrench and put it between the cylinders, then put a screw driver through the box end and you can turn it forcing the cylinders apart. It is really easy to spread them, and you don't have to worry about scratching shiat.
175
Topsfield MA (N of Boston)
it sounds like a bad idea, but i called bav auto before i did it & this is what they suggested...
i told em my pistons fully compressed but still couldn't get the pads in (i had em check the part # as well... they were the right pads)... so they told me to take some sandpaper, put it on a flat surface & go to town on the pads
took a while, since the pads were WICKED thick, but i got em down enough to squeeze em in... that was about 2k miles ago & no problems
63
Los Angeles
brakes/caliper/anti-lock
I have 2 questions, I plan on replacing the calipers on my E30. Does it take a lot of knowledge/special tools to replace calipers? I've done pads, Im thinking rotors aren't difficult. 2nd question is, does it matter what calipers I get, if my car has anti-lock brakes?
