dm_longhorn said:
What is the typical life-span of the e46 brake pads and rotors? I have 44k miles and I want to be prepaired to replace them.. not shocked when the day comes.
Is it worth getting the performance pads and rotors? I like the way the rotors look and I guess you could categorize my driving style as aggressive.
Howdy!
Kirby nailed the 'performance' brake parts aspect on the head.
I just had a total pad/rotor job done, Cost me just a few pennies over $300 for front/back Hawk HPS pads, front/back brembo rotors (OEM style, no slots, drills, etc), brake screws, and fluid. Cost $100 for the job - minus the brake bleed, I need to go back and get that done (bud just didn't have time that day to knock it out).
Yes I did get high performance pads, but nothing heavy-duty, mostly went that route to help cut back a little on brake dust. And I'm a pretty aggressive driver, my brakes get warm pretty quickly..
I got good prices on my parts, and a good price on the install - $400 total, I'd say your average range is going to be from 400-500, unless you have to take it to a stealership.
BTW I was just over 57k miles on my stock rotor/pads, but there were about as close as you can get to wearing on the sensor pad.. (Week later and I'd have been buying sensors too) Time may vary on when you need it done depending on your driving conditions of course. 44k does mean you're getting close.
Throw it on a stand, and take a look at the wear on your rotors (you can possibly do this w/o taking a wheel off, depending on how 'fat' your wheel spokes are - can you get a hand in there? Run your finger against the rotor - stock rotors have an outside 'lip', so you can 'feel' how 'deep' the wear is from the top of the lip (which does not wear at all). Check the front and back for even-ness of the wear, should be the same front to back.
