Changing Sidelights And Headlights Help Please
south wales, uk
hi, i have purchased a set of new sidelight bulbs and headlight zenon hid bulbs ( a kit 6000k one) and i need help installing them lol. i had a quick look at the sidelights and i took the plug off but wasnt sure how toget the bulb out, is it a twist and pull or something else? also, how hard a job is it fitting these zenon headlights? looking at it i reckon the harder of the jobs will be the sidelights? i hope someone can help lol.
regards
ryan
14
Akron NY
Sidelights- push the bulb in and then wiggle side to side. One way will move further than the other. Go that way. Don't force if it won't go. Than just pop it out. Headlights-there's 2 black tabs on the high beam and 2 gray tabs on the low beam. Grab ahold of both tabs and twist to the right. Wiggle a little and it should pop right out. DON'T touch the bulbs. The acid from your hands will bubble up and burn the glass. Good luck!!
