Where is the port to connect the code reader so I can check the cause of my intermittent "check engine" light? Thanks for any help. I drive a '98 328i sedan.
your obd port is under the steering colum area right in front of the clutch (if you have one) you may have to lay on the floor mat the first time to find it
