Cooling problems
Blue_E30
Santa Monica
Hi, i just purchased an 86 325es, and after driving it for a few hours i realize that the engine temperature goes high when ever i'm idling or driving at low speeds. However when i drive the car above 30mph, it goes into normal temp. or a little above normal. Is this a common problem, and what to do with it without spending too much money. THanks in Advance!
880
Pittsburgh, PA
Hi blue_e30
It is almost definitely your fan clutch. It is a very common problem with the 325's. I forget how much mine cost but what it does is gives the fan two different speeds. If your engine gets hot and the fan clutch will in a sense make your fan "shift gears" which causes it to rotate faster even though the engine is at the same speed.
Your engine gets cool when you are moving from the wind blowing through your radiator. When you are just sitting there the fan operating at low speed does not produce adequate wind through the radiator.
You can check to make sure it is the clutch and if you need tips for installing one, do a quick search in the forum. It has been discussed a few times. If you can't find it let us know. I'd be glad to discuss it again.
1,831
Winston Salem, NC
Yep - fan clutch is most likely bad. My car had identical problems until I replaced it. Easy job, I think it cost about $60 or so for the clutch. I know I've discussed it before, search my username.
rjp325i
511
Henderson, NV
I, like the others believe it is most likely the fan clutch, but if it isn't check out the cooling system for a partially opening thermostat restricting the coolant flow especially at low speeds. I have had that happen on my 1989. Above 35 mph it was fine but below the temp climbed. The thermostat should be changed every 2 or 3 years or so as a preventative. The BMW thermostats do not have a good longevity record.
1,831
Winston Salem, NC
Good point! I replaced my thermostat while I was replacing my fan clutch. It was actually stuck open and the temp would fall to the blue range on the gauge while driving on the interstate. And since the fan clutch was shot, the car would overheat in traffic. I had the worst of both worlds!
DoomSoko
Chile
Help!!
Hi.... I´m new to this forum and first of all i want to excuse myself for my english (i´m from Chile). Second, i´ve seen a lot of people with overheat problems, and that is a very common thing in the 3-series. I own a E21 323I '82 and got from the last five years enourmos problems with temp. I changed the fan clutch.. then I removed it and made the fan "directly pluged". worked for some time but nothing.. then i had it made a new radiator with more cooling capacity.. again one year ok. Changed the water pump, nothing.... I played also with the timing ("delayed" (para el que sepa castellano, pensé que podia estar adelantado)). I changed the thermostat, the indicator bulb.... Everything... maybe i´m missing something.
(i´m thinking to put an electric fan to see what happens or maybe control the on/off capability of the one from the A/C). Please help.
880
Pittsburgh, PA
DoomSoko
does it overheat no matter when? Certain speeds? While not moving etc.....
does your system pressurize? when hot try squeezing a rubber hose to see if it is pressurized. if not then it could simply be the resevior cap or radiator cap, depending on what you have.
DoomSoko
Chile
It only overheats when´s like 30 Degrees or above outside ( 88° + farenheit) and i´m stuck in traffic... otherwise when i´m running over 80km/h ( 50 mph) it runs ok and it lowers the temp. I checked and it has preassure.
880
Pittsburgh, PA
an electric fan would probably do it, though that would be a pain. Those are the same symptoms as i had before i replaced my fan clutch. I've heard of fan clutches going bad quickly. Did yours have any kind of warranty that would let you try another one?
368
Ventura CA
There should be a two-speed electric fan there already that is supposed to come on when the temp goes up. The switches for it are on the radiator. If you short one of them out the fan should come on and stay on all the time.
Steve
DoomSoko
Chile
mjbst111
It didn´t have a waranty of any kind... but it´s clearly working more than the "old one" ... it seems to be working ok. And yes, it is the one for the air conditioner. (i think i can buy a taurus electric fan and replace the original fan .. and control it with a integrated chipboard(i can make the software for it)
Steve
I have this two speed electric fan but i dind´t understand what you meant with "If you short one of them out the fan should come on and stay on all the time".
bddog
SoCal
New oversized radiator, new water pump, fan not slipping, have you considered the head gasket or a cracked block or head? Exhaust gases will heat up a cooling system. I've been there. Steve
DoomSoko
Chile
mmm but it isn´t smoking; it can´t be the cylinder rings or the block (thing i´m going to see when i check the compression) ,,,,, i straightened the head a while ago and maybe it was badly done... i´ll check that ( althaugh i have to buy a new head gasket while doing this)
49
Vermont
#16
if your interested, there is a company called flex a lite that makes dual stage fans for universal applications, supposed to keep the car up to 25% cooler or something like that, had one on a buddy's car seemed ok. Installations a breeze (pardon the Pun, intended) just take out the old fan and mount this instead. Took us about an hour to do
1,831
Winston Salem, NC
#17
DO NOT put a flex-a-lite fan on your car. The flex-a-lite fan is supposed to be a two stage fan because the blades flatten out at high engine speeds to reduce drag. Mounting a flex-a-lite fan to your engine requires getting rid of the fan clutch. You will see a decrease in fuel economy (sometimes a significant decrease) and much louder operation since the fan is directly coupled to the water pump.
But, the biggest problem I have with installing a flex-a-lite fan is that they are widely known to fly apart!!! Flex-a-lite fans used to be pretty popular on American muscle cars because most of these cars had pretty crappy stock cooling systems, and with modifications, they needed a lot more airflow than the original fans could provide. I have personally talked with several people who have had flex-a-lite fans on their cars that have come apart and thrown blades. You do not want to see the carnage this causes in the engine compartment - it almost always results in significant damage to the radiator and the hood. In addition, there have been numerous people who have been killed by getting struck in the head by a fan blade from one of these fans while adjusting the timing on their cars. Don't take the risk!
368
Ventura CA
#18
DoomSoko said:
Steve
If you pull the connectors off one of the switches and stick a piece of wire between the connectors the wire acts like the switch and turns the fan on.
Try both switches and just use the low speed one at first. The fan will run any time the ignition is on but it will keep the car from overheating when stopped in traffic, at least until you fix the real problem.
Steve
49
Vermont
#19
Did not know that...thanks for the info on FAL...will not use in future
Much obliged
Mr.W
Member
44
Germany
#20
Hey guys,
I am not sure if someone already metioned this, but when you do any work
on the cooling system besides topping fluid, you need to bleed the system.
If you dont, the cooling system will not cool properly.
