Do cluches ware out???
1,182
Dallas
do cluches ware out after 80-90k miles. me and my freind have a bet and i think they last as long as you dont jack them up or something
696
Places?
Hmm, yeah it depeneds on how you drive it. I was dropping it one night around every corner, I wore it pretty low, its not slipping But i can tell its worn
48
Gnome
Letting the clutch out fast (dropping) shouldn't slip the clutch. Slipping is what wears a clutch most. Say taking off in 5th gear from a standstill, that will wear a clutch disc pretty bad. Blueing the pressure plate and flywheel is also bad and will cause slipping. It reads more like you heated up the flywheel & pressure plate. Some people call it a shine. You shined the pressure plate, now your hosed. A resurface will fix this, not sure how long regular driving will take to wear off the shine or glazing. High horsepower heavy cars, like 454 Chevelle's could toast a stock clutch fairly easy. If you heated the clutch up in your car, you had to be slipping it really bad. If the gas peddle is to the floor, clutch peddle is up and the tires aren't spinning but the engine is revved up pretty good. I'd say the clutch is slipping...
1,831
Winston Salem, NC
My 325 has 230,000 on the original engine and clutch. It's getting to the point where it will be needing replaced in the near future. It'll slip just a little bit once about every four weeks.
328
Medicine Hat, Alberta, Canada
i once blew the clutch in one of my cars (it was starting to slip), by passing a vehicle on the highway and downshifting then shifting back into fifth.
vroom, *clutch and change gear* release clutch, pass, *clutch and into fifth* Vroom vrooom vroomm *pull car over*
