I have a '01 315i and live in the Phildadelphia area and when the cold weather set in I found that sporadically first thing in the morning when I get in the car the drivers door will not latch. I usually start the car and and turn on the defroster and heated seats and after about a minute I try to close the door and it latches fine. Yesterday I got in the car and the same thing happened but after a while the door still wouldn't latch, I manually pushed down the lock button and shut the door and it partially closed but was still loose BUT it also wouldn't open. Then after about two minutes the door shut fully. Only problem then was when I got to work the door would not open at all. (I had to climb over the console.) I tried to get in from outside but although the handle pulled out the latch didn't disengage. When I went out for lunch the door worked just fine! Has anyone else experienced this problem? Today I sprayed some silicone on the latch mechanism to see if that helps. ![Bang Head [?|] [?|]](/images/smilies/icon_smile_banghead.gif)
