Door Panel Removal
77
Toronto
Would anyone know where I can find a DIY for removing a door panel....its not that I cant remove it but Im just worried about the air bag on the door and if I do some wrong move and set it off....
So if you guys could let me know I would appreciate it
thanks
90
Calgary, AB
Air bag worries
Hi there,
The most important thing for you to do is to disconnect the battery before you start the job. After that, you can disconnect the airbag from the door without any worries... Just make sure that;
1. After it is disconnected, place it upright (frame side down, airbag side up)
2. Do not reconnect the battery with the airbag disconnected (it will set an airbag light in the dash)
Hope this helps,
Tiger
