I drive an 87' 325is, manual, with about 195,000miles
I have begun to notice a vibration that I can feel through my seat and hear. This occurs between about 25 and 30 miles per hour, independant of gear selection, and only under load from the engine (accelerating or going up hill) I can barely pick it out when cruising and I don't recall noticing it when running under compression.
These symptoms make me think it could be caused by the guibo or the center support bearing.
Is there anything else that it is likely to be? and can I tell by looking at or testing the guibo or CSB if either of them are the culprit?
Thanks in advance, I always apreciate the input.
