Are you there? I'd like to know if your brake booster is causing the brakes to stay on as it's pressurizing on my car under prolonged boost and slowly tightening the brake's grip on the rotors. It seems that the one way valve isn't designed for boost (obviously) and it can't hold the pressure.
Let me know if you're having the same experience. It's noticeable under left foot braking too, under boost the pedal is rock hard and you will have virtually no brakes.
I'm looking into a stainless check valve or potentially a dual master cylinder setup to rid the car of the boosted brake setup.
Al
Al
