Ok here goes, i recently got a good deal on a 318i 1996, BUT ... im having a few problems and wonder if anyone might have experienced similar things, firstly, the steering wheel sometimes sticks, have to turn quite hard to loosen it up and steer, almost as tho there is a loss of power steering or sticking in the steering column, tho this only happens when turning left, but heres my main problem, in first gear and to some extent in second the car 'judders' while pulling away, thru the rev range in 1st gear there are maybe 3 points at which the car jerks forward meaning that i have to rev very hard just to pull away at all, the jerking/juddering of the engine shifts the weight of the car backward and then forwards during 1st gear meaning that i have to catch the weight shift forward to change gear if im pulling away quickly. i have a manual gearbox with a reasonably recent clutch change, new spark plugs and leads. Im fearing an expensive trip to the car shop... .. hoping someone might know a little of this. cheers in advance.
