Vehicle: 2000 BMW 328Ci
Ok so i picked this car up a couple of days ago. I have been having problems with the car and the dealership has agreed to fix them. Here are the issues:
1. Both headlights go off and on randomly. They both go off at the same time. When this happens the relay in the dash can be heard clicking. Sometimes the headlights do it slow and sometimes the headlights do it fast.
2. Turn signal indicators act up. I put my left turn signal on but the left turn signal indicator on the dash will not work. Then the next time i try it goes very fast. Sometimes the indicator stays on after i have turned but the turn signal is not on.
3. Radio keeps blowing a fuse in the fuse box. Garage put a new fuse in and it worked fine for about 5 miles and then blew another fuse. When and put a fuse in it and now all the radio says is "Disabled" and will not work now.
4. On the dash the drivers side rear turn signal warning light is on but the turn signal is working fine. Does this randomly. Changed the bulb and the warning light went off. 10 minutes later and the light is back on.
Any help would be appreciated... thanks alot
