Has anyone replace the front brake pads? Does the sensor have to be replace
each time new pads are replaced. How hard is it to replace the sensor. Any help
comments would be nice. I was told the sensor goes on one side only, is that true.
If the sensor activated the light on your dash it needs replacing, if not you can reuse it, however I do not as they are cheap. Here is a DYI from Pelican Parts.
