this is what my freind replied with:
Yes, EGT = Exhaust Gas Temperature
It should be noted you want to locate the probe close to the engine's exhaust ports. Also, make sure the probe is no more than 1/3 the way into the piping. Contrary to old beliefs, it is actually the exhaust pulses that destroy probes, not the temperatures.
Wideband Oxygen Sensors
Cost is about 300-1000 US
Here are a few sources off hand...
http://www.innovatemotorsports.com - $329 w/ the Bosch Sensor
http://www.techedge.com.au - $398 w/o the Bosch sensor
You can buy a Bosch sensor from
www.1stvwparts.com for only $28
A wideband oxygen sensor can be used on any EFI system, but it is rare for it to be able to work with a stock ECU.
If it is possible to work with a stock ECU, then to make it able to work, you need to do a few tricks...
The output of a wideband box is usually 0-5v, sometimes linearized, sometimes not. However, some WB boxes have a separate 0-1v signal that can be fed to a stock ECU (and is there just for that purpose).
Otherwise, you need to run two sensors (one WB, one NB) if you want to give the ECU a narrow band signal.
A wideband lets you know how rich/lean you are. With a standard O2 sensor, you're either rich, lean, or just right. You don't know by how much. With a wb, you immediately know how much to adjust by, because you know just how off you are.
A stock 02 sensor is constantly varying the fuel to get better fuel economy during different conditions and types of engine load, and is called the lean run mode.
At WOT (wide open throttle) or high loads, the ECU defaults to the maps and does use the O2 for feedback and fuel economy. The wideband gives you better resolution concering HOW rich or lean you are.
The output of a standard O2 sensor varies dramatically with temp, so because of the wildly varying exhaust gas temp on a car it's only accurate within a small window of operation, namely light load cruise. The wideband sensor's control unit use sophisticated compensation software to calculate an accurate reading.
