i have a six speed manual 330i, and when i first got it, i used to put it into the over drive 6th when cruising the local roads around 45 to 50mph. the rpm sits around 17, 18 hundred, and it seems a bit low for my taste, esp when i try to adjust the speed up a bit. so i just started using my 5th gear to drive around town and use my 6th for highway driving. i still get pretty descent milage on 5th, so i'm wondering if i'll get couple more miles to the gallon w/ the 6th or not.
i believe the ratio on the 5th gear on my car is the same if not really close to the 5th gear on 5 speed manuals. i was just wondering what gear you guys coast around in, esp if you have a 6 speed box, ie 04 330ci, 330i or 03 330i pp owners. thanks
