hey guys, just got my 325is home and it has a few issues... first of all, the "check" light is flashing in between the gauges whenever the key is on, i assume that this means check gauges, the only gauge that doesn't work is the MPG gauge, does anyone know why this light flashes? Also, the Anti lock light is on, how do you do a diagnostic on the ABS system? Another problem i'm having is that the car takes a long time to start and when it finally does, it smells like gas, as if the engine is flooded, what might be causing this? Thanks very much for any help
