Hi Guys
I just bought my second used BMW 2001 325 CI convertible certified until 2-23-07.
Couple problem have appeared after owning it for 6 days:
- Service Engine Soon sign comes up when you turn ignition to level 1 then goes away after you start the car. What could it be?
- Washer fluid system not funtioning. When you activated you could hear the sound of it i have a feeling it is not pumping water. Any idea? Will this be covered by te BMW 100,000 miles warranty?
-after I floor it a sign comes up occasionaly (a catalog was not included but the dealer promissed to get me one) "!" inside a circle that looks like a gear in yellow color.
- I need to order a spare key. I heard i can go for the plastic one which costs $26 rather than the standard pricey one
Having onwed a BMW(European spec) before problems were more electronics(sensors,alternator...) simple to troubleshoot at any shop that has the software or hydraulics(steering pump, bushings, convertible piston cylinder....) .
I went for used parts as they were easy and cheap to get where i was.
Appreciate your feedback on this.
