Hi, I am new to this forum. But I've been driving my 02 325i for about 2 years now. It has 25000 km on it.
My concern is oil temperature is sometimes higher than the middle. The needle is about 5 degrees to the right of the centre. Has anyone else seen this? It's not always like this, only occasionally, but I am worried.
About 6 months ago, I noticed high oil temperature is slightly above normal. I went to the dealer, they found engine oil is 1 L less than normal, so they topped it up. The problem seemed to have gone away for a while. But a month later, it came back. This time, it's coolant, so I topped up coolant myself. Soon after, "Service Engine Soon" warning light came on. And the dealer replaced a"secondary air pump & divertor valve" under warranty. Since then oil temperature has been normal.
Just about two days ago, I started noticing high oil temperature came back! When I asked dealer, they checked sensor and found no problem. They just told me if you are driving in slow traffic, it's normal for oil temperature to be a little higher, all I have to do is to turn up heat and open windows. Is this normal?? what potential problem could it be?
I'm hoping someone has experienced similar problem and found root cause would help me out.
thank you.
thank you.
