I have a 1989 325i fitted with a Motronic fuel system.
When cold, the idle speed fluctuates between 500 and 900 rpm; when warm seems to be OK.
I have tested the Idle Air Stabiliser Valve as described in the manual using an ohmmeter and it is OK.
On testing the three cable plug connected to the stabiliser valve I have 12 volts at the centre cable and 9.8 volts when connecting between centre cable and one outer cable. When connecting between centre cable and remaining outer cable I have 3.8 volts.
I tested the continuity on wiers betwin ECU and stabiliser valve, wiers are OK can anyone tell me if is a computer (ECU) problem?
Thanx Mike,
Thanx Mike,
