Okay, the way Xenon headlights turn on is different than normal Halogen bulbs. They get
sent a "charge" to initially light up and it ain't no thang to light up your Xenons. Feel
free to use them as you normally would, but don't just sit in your car, turning your Xenons
on and off and on and off. This "charge" you send to the Xenons does hurt the bulbs just a
super tiny bit and it means nothing to turn your bulbs on normally, but when you just sit
there and do it repeatedly, you hurt the overall life of the bulbs, but it is kind of
marginal anyways. The truth is that it's only "testing that has shown that flickering the
Xenons several times on and off within an hour reduces the overall life of the bulbs."
This is why, even if you have Bi-Xenons, if you drive around during the day with the lights
off and flash your high-beams (you pull the stalk towards you), your inner halogens will go
on and off instead of the bi-xenons. This is a step that German car manufacturers take to
preserve the bulbs.
Now as for the "Auto" feature, this is a great feature but also leads to potential bulb
abuse. If you park in a garage and you have the "Auto" feature set on all the time, the
lights will turn on every time you start your car, and then will turn off once you leave.
This isn't a big deal, but again, to do this every time you take your car out for the day
or whatever, these unnecessary "light ups" affect the overall life of the bulbs. Or if you
drive around a highway with overpasses or go through toll booth gates, you'll see that your
Xenons will also unnecessarily ignite. On the Cross Bronx Expressway (lots of traffic and
overpasses) I often see cars' lights automatically turning on and off for no reason at all
and going through the Cross Bronx to the GW Bridge, the auto lights will ignite people's
Xenons at least 5-10 times and this is terrible for the lights!
Clearly, the "auto" feature still has not been perfected yet. My best advice is to leave
the headlight switch on "off" and then when it's not time, put the switch on "Auto" and
leave it on the Auto setting for the whole night until you park your car overnight, then
put the switch back to "off". This way you enjoy the benefits of the Auto switch without
abusing your bulbs.
A personal system I have come up to potentially resolve this issue is that maybe when you
have the bulbs on "Auto" setting and the darkness triggers the lights to go on, then the
lights should turn on and stay on for 5 minutes, regardless of lighting conditions. So
let's say you turn on your car in your garage, and the lights turn on because you have the
Auto feature on. Then you drive around and for those 5 minutes, even if it's bright and
sunny, the lights will stay on. If the sensor does not detect any more darkness during
those 5 minutes, only then it should turn off the ligths. This should resolve the constant
"on and off" issue with highways such as the Cross Bronx Expressway I mentioned earlier.
But the lights will still turn on when you start up the car or enter a garage in the middle
of the day, which might be unnecessary....but if you live in an appartment or something and
you have to navigate through a garage to get to your parking spot, it is a nice safety
feature to have the lights go on automatically as soon as you pull into this garage
(although completely unnecessary if you park in your own 2-car garage or something).
Overall, basically you can just leave it on the Auto setting for as long as you want or
follow whatever system you prefer (such as the "auto" setting on only at night, and then
"Off" for the rest of the time). Although it might give your Xenons some unnecessary
"abuse" to have the bulbs on Auto all the time, the bulbs still do last 4-5 times longer
than Halogen bulbs and if you ever do have to replace your Xenons, they will be well worth
the $200 for the pair.
(PS Not written by me
![Stick Out Tongue [:p] [:p]](/images/smilies/tongue.png)
Written by an elussive member of this forum. [bmwdance]
