looking for info
xanthus29
3
Germany
I moved over to germany and bought an '89 320i. Its euro spec and didn't come with a manual (and not knowing german, I couldn't read it anyway). I'm wanting find out more about my engine and other parts I can change to improve performance, but having trouble finding any info about my car. Does anyone know of any webpage or any books I could check out to learn more? Thanks.
xanthus29
3
Germany
I did try google. For quite a while. Unfortunately, I couldn't really find any good info I could read (all in other languages). Since there were no US spec 320i's made in '89 its pretty hard to find info about my car in english.
73
San Diego
use the google language translation feature. you can translate websites or blocks of text. look to the right of the search bar on the google main page. you should see a link that says language tools, press that and the rest is easy.
xanthus29
3
Germany
It looks like I found some of what I was looking for. Got it from a search of yahoo.co.uk
Thanks much!
320i, (E30), 1990 cc, 1986-92, Engine Code 20 6E/K E/A
Ignition Data
Ignition system type: El-ecu
Ignition coil make/type: Bo/0 221 118 335
Supply voltage: 11 - Volts without ballast resistor
Primary resistance: 0.82 Ohms
Secondary resistance: 8250 Ohms
Distributor make/type: Bo/0 261 200 152
Contact breaker gap/air: n / a mm
Dwell angle: n / a Deg
Ignition Timing - unleaded: n / a Deg eng/rpm (without vacuum)
Ignition Timing - leaded: n / a Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: Pulley
Firing Order: 1-5-3-6-2-4
Spark plug make: Bosch
Spark plug type: W8LCR
Electrode gap: 0.75 mm
Fuel System
Fuel type: L/U +Cat
Fuel pump type/pressure: Elec/2.45-2.55 bar
Engine idle speed: 760  40 rpm
Fast idle speed: n / a rpm
CO level at idle speed: 0.7  0.5 Vol %
Engine Data
Valve clearance - inlet: 0.25 c mm (cold)
Valve clearance - exhaust: 0.25 c mm (cold)
Compression pressure: 10-11 bar
Oil pressure: 0.5-2.0/800 bar/eng/rpm
Radiator pressure cap: 0.9-1.15 KRB250 bar/type
Drive belt 1 - size: 9.5x960 KDB960 mm/type
Drive belt 2 - size: 9.5x825 KDB825 mm/type
Electrical System
Alternator output: 80/2500 Amps/eng/rpm
Regulated output: 13.5-14.2 Volts
Battery: 12/50 V/Ah
Starter motor make/type: Bo/0 001 311 151
Other Data
Clutch operation type: Hyd
Clutch adjustment: S/Adj. mm
Cambelt failure: Damage
Cambelt Part Number: 11311713361
Tyre pressures: 2.0(28)f 2.0(28)r bar (psi)
174
Oregon
http://www.e30.de/index.html
That is a pretty good site with lots of info but it is in german. I have a translater program that works well, its called Web Translater 3.0. No joke, that is what is says. I can read about 95% of that website. I thought I seen some info about the 320i there.
Later
