Moon Roof Does Not Close Completely
hbaldana
10
Gaithersburg, MD
Hi, the moon roof on my 323i does not close completely in auto. It almost closes, it stops, goes back a few inchews and stops. Then I have to hold the switch until it closses.... HELP!!
Thank you.
90
Calgary, AB
Sun/Moonroof
I agree with Ngekelly.
The sun/moonroof motor has an anti-trap mechanism.
When the motor senses a higher than normal resistance, it stops itself and opens a bit (like if your fingers were to get trapped, it would stop and open enough to get them out).
Using a spray lubricant (white grease, like for door hinges) should get rid of this problem.
104
netcong nj
clean and lube it with the clear spray silicon, and then pull down on the head liner under the rear of the sun roof so the shade has alittle more space to slide, then reinitialize it by pressing and holding the tilt up button untill it makes a clicking sound like it over extended, then, press and hold the open button untill it reaches the rear and stops, then press and hold the close button untill it closes and stops
