Alright starting yesterday, I had a few odd problems.
New Problems on 4/12:
-License Plate Frame light came on (Check lights) but went out after restart
-Low Coolant light (Check lights), but again, turned off after restart
(Note: None of these came back on 4/13)
New Problems on 4/13:
-Shifter started to vibrate creating a LOT of noise in 4th gear. Everything enguages correctly and stays in gear, car drives fine, but the vibrating is annoying.
-Rattle coming from ceiling in rear, mostly evident when accelerating slowly in first gear when exhaust/engine reaches a certain frequency but then goes away.
-Rear end appears to be sagging, suspension needs to be replaced, but why would this just start now?
-When decelerating slightly, there is a repetitive sound coming from the rear of the car that will varry from wheel/axel speed (not engine speed). Sounds like a wheel bearing but it only happens when slowing down without brakes in 4th gear. Any ideas?? I am thinking it could be the center support bearing or guibo which could explain the 4th gear shifter rattle?
Maybe it's the rain.
