Hi all,
I'm new to the board, and a proud owner of my first, and new 6spd E46, 330xi. I've had it about two weeks and since delivery I discovered a low frequency hum/vibration at speeds above 65 under light acceleration. This occurs in 4th, 5th, and 6th gears, (I haven't pushed the motor to see if it would happen in 3rd gear, but suspect it would. No vibration is felt when coasting through 65-70 mph, with the clutch depressed.
The vibration is felt, more than heard, and is steady at speeds above 65, it also increases and decreases in intensity at a steady rythem, about 1-2 seconds at 65, and less as I accelerate. There is no vibration from the gear shift. It is significant enough to vibrate and shake the mirror to blur the reflection.
Been to the dealer twice, first time they claimed normal road noise. I took out a tech, and demonstrated, and now dealer ship wants to change out the transmission. There's only 1500 miles on the car.
There is no vibration from the gear shift. When I question why is it the gear box, and not another component of the drivetrain, there is no clear answer.
Any help, suggestions, or ideas would be greatly appreciated. Thanks in advance. There is always a wealth of knowledge at these user forums, and I really need it.
