320 IA 1997, was working great, suddenly wanted to use it it didn't start. starter is working, battery is perfect, i checked all the fuses, etc.... then going to check the fuel pump i was trying to remove it's connector i tried to run the car and it run!!!! the next day it did not run, only the starter.....
any idea? where i can locate the fuel pump relay cos it is not next to the fuse box as it is mentioned in my wiring diagram.
thanks
thanks
