Sounds like your sensor crapped out on you. It's going to temp automatically when you start the car because below 38 degrees, it automatically switches to the temp display, dings at you, and the Farenheit symbol flashes to warn you of possible icy road conditions. On my car, the temp sensor is underneath the car up behind the air dam above the plastic front engine cover.
