Just the Facts, Maam! (Long)
Bmw 325i 7803 said:
You get another when the indicator hits zero unless the dealership goes postal and resets it...
That's a fact - Jack.
There seems to be a lot erudite opinions offered within this thread. To cut through the armchair opining, BMW's actual position on this matter is provided below.
BMW issued SI Bulletin 00 04 01 today (10/25/01) to clarify the oil change situation for low annual mileage owners.
“A limited number of BMW owners accumulate very low mileage on their BMWs annually, in some situations insufficient for the Service Interval Indicator System to call for an Oil Service or Inspection. However, all BMWs should have an engine oil change at a minimum of once a year, regardless of whether synthetic or petroleum-based oil is used.”
As a part of the BMW Maintenance Program your dealer should perform the annual oil service and update/stamp the Service and Warranty Information Statement but SHOULD NOT RE-SET THE SERVICE INDICATOR SYSTEM.
If your driving pattern remains constant (i.e., low mileage) the Service Interval Indicator System will under most circumstances (i.e., excluding really low annual mileages) call for an Oil Service within the next 12 months at which time your BMW Center’s service department should perform the oil service (including oil filter replacement), update/stamp the Service and Warranty Information Statement and RE-SET THE SERVICE INDICATOR SYSTEM.
If the annual oil service occurs within 60 days of the time when the Service Indicator System would call for an Oil Service or Inspection, then the upcoming service should be performed and the Service Indicator System reset.
In situations where you request a more frequent oil service (at your own expense) than as called for by the Service Interval Indicator System, the same logic applies – your dealer should not reset the Service Indicator System until the maintenance is performed that is called for by the System. This is especially critical for vehicles still covered by the BMW Maintenance Program."
