I just had my car at Mr. Lube to check the air pressure, and i went underneath and i noticed that there was some slight leakage from my axle seals. I was like "well that sucks" so i then asked the guy there (my friend) to check the diff oil level and i had overfilled it.
I read on the net that overfilling your diff can press out the axle seals. If my seals are leaking, i most likely need to replace them now? They aren't leaking fast, i am sjut worried about dirt getting into the diff.
Anyone know the fluid capacity for a 3.91 LSD differential? (out of curiosity)
I als have NO IDEA how i managed to over fill it either, since the car was SUPPOSED to be on level ground.
Do you think i need to replace my seals ASAP, or can it wait til next summer?
