Hi guys i am new to the BMW scene but i love the e30. I have a chance to buy a 1986 325 es w/172k in near perfect condition. The following parts have been replaced: Engine reseal, Timing belt-Water pump-Tensioner-Seals, Clutch-Pressure plate-Release bearing, Shifter rebuild, Belts-hoses, Brakes (Hawk, Brembro), Tires, Alignment, Plugs-Wires-Rotor-Coil, Thermostat, Temp sensor, Intake boot, K&N, Drive Shaft-Center bearing- Guibo, Valve adj., Fluids including brake trans diff antifreeze oil filter, Antenna, Emblems, Dinan chip, Windshield, Bulbs, Wipers. Seems to me like most of problems that would surface at this age have been addressed, btw the KBB says like $2000...thats seems cheap to me. Thanks!
