I've been having a strange problem with my 2000 323i and I was wondering if anyone else has had the same experience. Usually on cold mornings after the car hasn't been driven for a while (say, 12 hours), when you turn it on and shift into reverse, it won't budge. The rear of the car will rise up (literally higher off the ground) as if there is a wedge stuck under the tires (which there is not), and it won't move. If you then shift into drive, the car makes a loud clanking noise. And if you then shift from drive to reverse, the car behaves normally and it is drivable. Any input?
![Confused [confused] [confused]](/images/smilies/confused.png)
