or just check your fuel cap, or maybe the door sills....could also be in the manual. there is a little table showing the pressures for several sizes. maybe yours is within.
You should be fine with 30 - 33 lbs for the street. Try different combos and see what you like best. For a driving school you will need more than what you use for the street. Try contacting the Tire Rack, they should be able to help.
A driving instructor on another site said I should run no more than two pounds more than the original tire pressure. This made sense to me and I think that's what I'll go with. It's also right in line with most of the reccomendations here.
Remember the load you carry in the car calls for different pressures. My '89 325i door jam sticker says 32 lbs front and rear for light/normal load and 33 frt and 41 rear for max load. Try a couple different combos. See what works best for the street for you and use it. I like and use 33 lbs all around for the street.
I'm finding that all the models are a little bit different. My 91 325iC is 29 front and 32 rear. Basically I'm gonna run 31 front and 34 rear and see how that goes.
Your driving style and handling preference will determine what works best for you. A slightly lower (a pound or so) air pressure than your starting point in the rear will lessen understeer if you desire. Try different combos and use a quality air pressure gauge. I have found a digital gauge (Accutire) works best for this purpose.
