I'm guessing that the static height is off, this is part of the TAB replacement procedure. The procedure is in the Bentley, follow the instructions about replacing TABS. Look specifically at the instructions regarding tightening the TAB center bolt to align the "console" to the hub.
THIS PAGE has a detailed discussion on replacing the TABS, and also aligning them. Scroll down about halfway to see the alignment info, this picture. You can see that the BOTTOM of the console should project a line that is 8mm above the centerline of the axle. My guess is that yours is rotated lower due to the force of spring removal.
There are a couple of things to watch/plan for. I just know the pain of experience and can offer some tips and pointers!
- From the picture you can see that you will have to remove the "console" bracket. The 3 bolts might be rusty. Spray some PB Blaster, WD40, whatever. I had to replace one of mine, it was too rusty for my satisfaction.
- BE SURE to mark the exact position of the bracket before you loosen the 3 bolts. You want to get the bracket back in the same place to maintain alignment. (Of course, since you changed springs/struts, you
need to get a 4 wheel alignment anyhow.) This will just help to keep it close.
- Loosen the center bolt and set the static angle. Do your best but don't worry about 1mm difference.
- Put some lube on the bolt threads before you tighten it, so you can get it good & tight.
- When you go to put the bracket back into the frame, it will be a biatch because you will have to force the bushing to twist into place. Remember how hard it was to push down? It's kinda the same. My trick is to use the floor jack to gently jack the bracket into place, enough to get the bolts engaged by 1/2" or so. Then turn each bolt 1 revolution at a time to line up the bracket and pull it into place.
This probably sounds confusing, but with the Bentley and the web site, you'll figure it out pretty easily. Good luck!!
