So I finally did it after 120,000 miles. I know I really should have done it earlier, but it seemed like it might be involved. Wow, what a joke. Pop the fill bolt, pop the drain bolt, let it drain, pump in the new stuff and close it up. Couldn't be more easy (well....it did take four stores in Atlanta to find a 14mm alan wrench/hex bit).
Two questions:
How often do you guys drain your differential fluid? (Does anyone really believe it's "life time"?)
What oil do you guys use? (I put in Mobil 1 Synthetic 75w90...should of only taken 0.95 liters but an extra 0.1 liters seems to get lost in the pump.)
Two questions:
