Hi guys,
Driving the other day I notice my car steering wheel voilently shake and I thought it was possibly my lug nuts coming loose so I got out and checked them but they were all on tight. Got back in my car and vibration went away. Then I notice it comes on and off once in awhile. I jack up the front end of my car to have a look and check out the rotors and pads. Pads were fine but I noticed that the passenger side wheel spins freely when I spin it and the drivers side seems to be tight like the brake is slightly on. I took it for another test drive after finding my brake pads were ok. I noticed that when I pulled up to the light, to a rolling stop, my car slows down like the caliper on the drivers side is stuck possible causing the wheel to vibrate and pull to one side. Tested in on a hill, and my car didn't rolls down. AHHH!!!! Anyone heard of the caliper pressure or getting stuck in position??? Do you think this is a rotor problem? I am going to grease up the caliper pistons to see if they loosen up a bit. Any advise would be helpful. Thanks in advance.
Oh, I drive a 2000 323CI w/60K miles
