I have a 330ci/04/ with spt,cold, and prm. Packages it has 12xxx miles on it.
I only use v-power gas form shell.
Now the problem:
I started the car and gave it a minute to let the rpm get normal; which I always do. When I drove less then a mile and the following lamps turned on “service the engine soon; EML” and the engine was making a weird sound like, missing. When I pushed the gas paddle but there was no response. There was no power, so I stopped the car. Few minutes later I started the engine again and everything seems normal, sound was ok no more light came up.
Does anyone know what is going on; it is almost a new car. I did change the oil at 8000 miles; and I did get an appointment with the dealership regarding this problem
In advance; thank you for your comments and suggestions.
Moonjuction
Now the problem:
Moonjuction
