Can someone explain the "tempurature control wheel" in the center of the front air vents. I read th emanual and understand what they are suppose to do. My question really is why is this needed.
I have auto temp. control in my car. Isn't 70 degrees, 70 degrees regardless of where this wheel is (blue or red)? ny what is the white line in the middle?
What do other do? Do you keep switching between the red and the blue to adjust the temp in the car? It seems I can change the tempurature by 3 - 5 degres just by rolling the wheel, or do you leave the wheel in one spot and change the tempurature in the climate control?
I'm sure this has been discussed before but I'm still new.
Thanks.
Thanks.
