I replaced the clutch and throwout bearing 2 weeks ago becuase of a failing throwout bearing.
The new one makes the SAME noises if the tranny is in neutral and I let off the clutch. It makes that fun rattling sound. The pedal is smooth as SILK but I assume that just by design, the release fork itself doesnt 'pull' at the throwout bearing, just pushes it, and just hopefully the throwout bearing would loose contact with the fingers on the pressure plate.
Is this just normal? I'm 100000% positive we did everything right.
