Tire Pressure
4,412
Wayzata, MN
it should say in your owners manual, as well as inside the drivers door sill. if only i owned a 330i zhp, then i could just go out and check mine [burnout]
4,412
Wayzata, MN
owners manual then would for sure have it. what part of the door sill are you checking, it should be the back/upper part of drivers side.
if you were parked, and passed out, and someone in the passanger seat pushed you out the door, it would be about the spot you would hit your head, at least thast where it is on my e36.
41
Alabama
Front 32 psi, rear 38 psi is what I run and is what is printed on the door and in the manual. They also have a second set of numbers (higher) for when you are hauling 4-5 people and luggage.
493
Kapolei , Hawaii
jrt67ss350 said:
Is there a story behind that, Dan??? [:p]
Sounds like it . Maybe he has the tire pressure's imprinted on his forehead and doesn't even know it . [joke]
I like to run 1 or 2 psi higher to try and squeeze out a little more mpg ..
4,412
Wayzata, MN
haha, no, it was just the first thing that came to mind, i couldn't describe it any other way.
and thats a good idea about tire pressure on my forehead, maybe i'll get a tatoo of what psi to run on my forearm [nutkick]
